While you have probably used the Text Tool or Dimensions in the past, you may not know that you can change to look of your text or place text on the screen! Join Aaron as he walks through a whole slew of tips on how to make your SketchUp text and dimensions look as good as possible!
Recommended Articles
From commercial to residential builds, Scott Miller from Remington Development Corporation uses the SketchUp suite of tools to perfect the conceptual design process.
SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
