Extension Inspection: Material Resizer
Take control of the size of the images in your SketchUp file. Material Resizer is now available on Extension Warehouse! Download for free: https://extensions.sketchup.com/en/content/material-resizer
The SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
Trying to use shadows in your SketchUp model? Follow along in this quick win as we show you how to create a shadow study template using shadows and scenes in SketchUp.
