09. Use one layer: Layer0 (or minimal layers)
This video is part of a larger series on modeling for 3D Warehouse. View the full playlist here: https://www.youtube.com/playlist?list=PL-bndkJaV8A75zuNAf0A5NCfF8beEve7V
