[Quick Win] Editing components using the modifier tool
June 20, 2019
Have you ever needed to modify geometry that is deeply nested within a SketchUp model? If that item is a component, you can use the modifier key to move a copy of that object out of the model to edit it. Since it is a component, that object is automatically updated within your model so you can delete the copy and continue on with finalizing your SketchUp model! This Quick Win comes from SketchUp forum user, JimD!
Previous Video
[Quick Win] Resizing your circle with cardinal points
Did you know that when you draw a circle the corners that meet the axis are called cardinal points? If you ...
Next Video
[Skill Builder] How to get the best performance with a large model
Using inspiration from Matthew Nicholl's 2018 3D Basecamp presentation, we give you a few tips on how to op...
