Tips for Designing a Net-Zero Energy Home
In 2015, we wrote about the Iowa Nest, a net-zero energy single-family home in rural Iowa. Designed by Carl Sterner of Sterner Design, now with Sol Design + Consulting, the project combined an optimized form with passive and active design strategies to achieve net-zero energy status and an outstanding annual utility bill of only $24!
Where most designers simply dream, Sterner and his clients have rigorously tracked and compared the performance of his as-built project against his proposals. We’ll recap some high-level design moves and share five learnings from his post-occupancy assessment.
Project Stats
- Project type: net-zero energy target, single-family residential
- Building type: single-family residence
- Floor area/occupancy: two stories, 2400 sq. ft. living area (plus unconditioned storage and garage)
- Project stage & completion date: completed in 2019
- Performance baseline: IECC 2012
- Performance goal: net-zero energy, good daylighting
The home, post-build. Image courtesy of Sterner Design.
The Design Process
The firm tested a few different design iterations to achieve its net-zero energy and daylighting goals. First, six forms were modeled in SketchUp and analyzed in Sefaira with the goal of maintaining at least 200 lux daylighting for 60% of the year in the main living areas.
Building form iteration studies modeled in SketchUp and analyzed in the Sefaira Daylight Analysis plugin. Image courtesy of Sterner Design.
The final design incorporated a narrow plate, compact shape, taller windows, and an interior “light well.” Once the ideal conceptual design was found, the challenge of maintaining a steady, passive temperature in a mixed climate with very cold winters and hot, humid summers was addressed. Eleven design strategies were analyzed using Sefaira, leading to the decision to specify an Insulated Concrete Formwork (ICF) and a combination of small fixed overhangs and operable shading screens over the south-facing windows.
Daylight analysis using SketchUp and Sefaira. Image courtesy of Sterner Design.
All the design decisions above, plus passive strategies (natural ventilation, an optimized building fabric, shading devices), and efficient mechanical systems, resulted in a predicted 79% reduction in energy use from the code baseline. South-facing, roof-mounted solar photovoltaic panels were designed to meet the family’s energy demand and moved the project to net-zero status.
Energy use comparison showing a conventional house design vs. the Iowa Nest design. The combination of design strategies led to a 79% reduction from the International Energy Conservation Code 2012 Baseline. Image courtesy of Sterner Design.
To test how these design strategies performed over time, the occupants have diligently tracked the home’s temperature and relative humidity at three locations across the house, and energy use was metered on a per-circuit basis. This makes it possible for the owners to map energy use to specific spaces accurately. Here are five lessons that can be gleaned from the numbers and the design process.
1] It’s okay to shape-shift.
Designers are very familiar with the concept of iterating on design ideas, and this project reinforces the value of testing and analyzing multiple building forms before locking in a selection.
The original proposal turned out to be two times over budget. By simplifying its structure and slightly reducing the floor area, Sterner Design was able to cut construction costs in half, bring the design within budget, and achieve a 30% reduction in heating & cooling loads.
Comparing heating and cooling loads across design options. Design alternative B achieved a 30% reduction in EUI. Image courtesy of Sterner Design.
Reflecting on the journey to the final built form, Sterner recommends that “..carrying out a form study that compared compact vs. elongated forms would have made for a more efficient way to identify the ideal building form.”
Quickly modeling and analyzing these simple Whitebox models in SketchUp and Sefaira allow for the efficient comparison of buildings based on form. Image courtesy of Sterner Design.
The learning: Quickly model and analyze multiple forms to find the energy and cost-saving opportunities.
2] Where possible, refine and simplify.
Changing the form and resulting complexity resulted in a 10% decrease in energy use.
One of the hallmarks of good architecture is that creativity and function merge to create a refined, almost unquestionable built form. The benefits of ‘simplifying’ to crystallize your design go beyond simply delivering great architecture and increasing buildability; it can also drive energy use down. By reducing the number of junctions, corners, and connections in his original proposal while still delivering his client’s spatial requirements, Sterner Design achieved a considerable 10% reduction in energy use. According to Sterner, “This experience has shown me how tightly intertwined design and performance are. By reconsidering some of the basic design moves, we delivered a more energy-efficient design with a 50% reduction in capital cost compared to the original design. Net Zero or Passive House design is not something that can be easily tacked on to a design at the end -- it needs to be integral to the design's DNA.” Analyzing design options early and often created the opportunity for more meaningful client conversations: hard data gave the clients the confidence to approve changes that were still delivered on the brief and saved them capital and operating costs.
The lesson: It’s certainly worth keeping things (relatively) simple. Crystallize your design to deliver great architecture, increase buildability, and drive energy use down.
3] Choose the right active HVAC systems.
Designers will agree that specifying the right HVAC system can elevate or tank your passive efforts. Not only can it lead to space savings and a better internal environment, but your HVAC choice can also spike capital and running costs for your client.
Again, leveraging Sefaira’s HVAC analysis early and often to test system combinations that could work for your specific site and project could be the difference between your client spending or saving thousands of dollars.
The Iowa Nest ended up with HVAC systems that were cheaper than conventional, but that provided better comfort and indoor air quality and contributed to it achieving net-zero. How? Firstly, by eliminating air conditioning, which is not an easy feat in Iowa's mixed climate.
HVAC system cost comparison for the design. The middle option was the original proposal and the third option reflects the final design. Image courtesy of Sterner Design.
The project incorporates passive design strategies such as earth berming, shading, natural ventilation, and minimization of internal loads. This reduced cooling loads to such an extent that the designer could avoid air conditioning altogether. Similarly, high insulation, good air-tightness, and passive solar design reduced heating loads to such an extent that he could specify a small, cheap, electric radiant heating system.
While the inefficiency of electric radiant heat is typically a poor fit for a net-zero home, in this case, loads were so small that the energy penalty was marginal and could be easily made up by some additional PV panels.
The lesson: Look at HVAC and envelope strategies in combination.
4] Draw the details.
Detailed specification notes for the home’s window insulation. Modeled in SketchUp with comprehensive drawing sets created in LayOut. Images courtesy of Sterner Design.
Sterner leveraged SketchUp and LayOut to draw and produce a comprehensive set of typical and bespoke details to achieve airtightness and a stable internal environment. He specified how typical wall details, bespoke wall junctions, windows, and doors needed to be air sealed and insulated.
The home’s air-tightness layer is highlighted (left). The home’s thermal insulation is highlighted (right). Image courtesy of Sterner Design.
This level of rigor resulted in an airtight interior with no draughts and little to no internal temperature fluctuations, despite a recorded annual temperature delta of 70oF on the site.
Temperature comparison data showing interior temperatures (blue, pink, and red lines) against. outside temperature (black line) with no active heating on during the polar vortex of February 2021. The design delivers steady, comfortable internal temperatures despite exterior fluctuations. Image courtesy of iowanest.com.
The Lesson: Drill down to the details and specifications to ensure an excellent build and occupant comfort.
5] Beyond EUI: Passive Strategies & Metrics.
Although EUI is great for benchmarking and understanding how good a design is overall, it is not a great design metric. It can hide potential problems, particularly around thermal comfort and high load issues. Further along the design process, an engineer observed that the original proposal, which would have cost twice the budget, would likely have had cold bedrooms in the winter and a sweltering office in the summer. This uneven distribution of heat may also have required a more complex, expensive, and/or larger HVAC system to alleviate.
By performing thermal comfort analysis using the operative temperature metric, the team could eliminate the need for air conditioning, specify a smaller, cheaper HVAC system, and avoid uncomfortable rooms within the home.
Once a reasonable EUI baseline is established, it pays to assess other metrics such as peak loads, operative temperature, and thermal autonomy (the percentage of time a space maintains comfort passively), providing more granular & meaningful insight during design.
The power of passive design strategies - With the final project cost, including valuing the owner’s self-build time at standard labor rates, the build still cost 9% less than a conventional home.
More information about the project, including thermal comfort and energy data, is available at the home’s website, www.iowanest.com.
About Carl Sterner
Carl is the Director of Design and Sustainability at Sol Design + Consulting. He oversees the design and delivery of highly sustainable projects, including Passive House, LEED Platinum, and Living Building Challenge certified designs. He believes in the power of design to help bring about a more humane, equitable, and joyous world.
