How long does it take you to model a building in SketchUp? Ok, how about a city block of buildings? How about two dozen city blocks, including all streets, sidewalks, buildings, water and trees? If your answer is "More than 6 mouse clicks," then you NEED to check out this episode of Extension Inspection! Check out PlaceMaker on Extension Warehouse.
Recommended Articles
The SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
![[Quick Win] Creating a Shadow Study Template](https://content.cdntwrk.com/mediaproxy?url=https%3A%2F%2Fi.ytimg.com%2Fvi%2F93yIhFa19PE%2Fhqdefault.jpg&size=1&version=1586206877&sig=09515c79ef1e21506954374c37b21a30&default=hubs%2Ftilebg-videos.jpg)
Trying to use shadows in your SketchUp model? Follow along in this quick win as we show you how to create a shadow study template using shadows and scenes in SketchUp.
