Remodeling a Faucet Part 4 - Merge Surfaces with Move Tool Method
This video shows how to merge two surfaces together using the Move tool on individual vertices. It also furthers the faucet by modeling the aerator for the water outlet.
Should you use materials or images? In this Skill Builder, we look at how you can use materials to fill in the colors on your model versus using imported imagery.
