[Skill Builder] Dynamic Component Fence Part 2
Jump into part two of our Dynamic Components - Building a Fence series, and learn how you can apply a little math to your components to place your fence posts at maximum spaced even distances.
Join the forum: https://forums.sketchup.com/t/modeling-an-ornithopter-from-the-upcoming-dune-movie-live/136358
