SketchUp Success for Woodworkers: Define and conquer
May 11, 2018 David Heim
David Heim has been using, teaching, and writing about SketchUp since 2007. He’s edited three books about SketchUp and produced more than 400 furniture models for the 3D Warehouse. This blog post is adapted from David’s new book, “SketchUp Success for Woodworkers.”
Sequencing the modeling of a simple table
Defining a modeling sequence is the key to producing a clean model.
In woodworking, there’s a sound, logical sequence of steps you need to take from start to finish. It’s the same in SketchUp, so work in SketchUp the way you would in the shop: define the steps and sequence you need before you begin modeling.
Suppose, for example, that you’re designing kitchen cabinets. The best way to do that is to begin with the cabinet sides. They’re the main structural element, holding the other parts in place. Draw one side to size and add rabbets and dadoes for the bottom, back, fixed shelves, and toe-kick space. Copy the side and do a Flip Along command to mirror it (this orients the copy correctly, without creating redundant geometry). Fill in the fixed shelves, the bottom, the back panel, and ledger strips. Next, attach a face frame. After that, position whatever drawers, doors, and adjustable shelves you want. Finish by adding knobs, pulls, and other hardware. Those are the steps and sequence you’d use to build the project, so that’s the way you should model it.
Technicolor Cabinet
You might not want this technicolor cabinet in your kitchen. I added the color-coding to show the logical sequence of steps to build a model in SketchUp and the real cabinet in the shop.
You can follow pretty much the same sequence for any case piece—essentially a box with shelves inside and a door on the front.
With a more complex piece, such as a dresser or a sideboard, constructing the SketchUp model as you would the real thing allows you to preview the glue-up. By using SketchUp’s X-ray mode, you can peer into components to see if tenons clash with others, if dowel holes align in mating parts, and so on. It’s a sort of a dry fit for the dry fit.
Dresser in X-ray mode
SketchUp’s X-ray mode is invaluable. It lets you look inside components to be sure all the joinery lines up properly—before you begin shaping real wood.
In the shop, you begin a project by milling all the wood square and to its final width and thickness. With that done, you go on to cut pieces to length, adding the joinery and dry-fitting the pieces.
You can work the same way in SketchUp, although it’s not a good idea to make all the components at once. It’s better to add components in place so they fit precisely against mating pieces; that ensures that each new piece will be the exact size you need.
To take a simple example, suppose you’re making a small occasional table with tapered legs, connected to stretchers with mortise-and-tenon joints. The first thing to do is define the first step in your modeling sequence.
Simple table, simple sequence
A simple table with an important modeling question: where to begin?
As you would build a table, begin with the legs. Start with one table leg without a taper or mortises. Copy that leg component, and do Flip Along commands to position all the legs so that each leg component has the appropriate orientation. That’s easiest to do when they are square. Open one leg component for editing and create the taper.
The next step in the sequence is to make the stretcher. Draw one in place between two adjacent legs. Give it thickness and make it a component. If the table is rectangular, repeat for the second pair of stretchers. Copy the stretcher components and position them between the legs: a rotational array works well here. Add tenons to the ends of the stretchers to set yourself up for the next step in the modeling sequence.
Rotating stretchers
With table legs in position, add a stretcher. Spin a rotational array to position stretchers between all the legs. Guides will help you identify the center of rotation. Make sure all of your components maintain proper orientation as you create them.
Now, similar to how you would in the shop, use the tenons to size the mortises (in the shop, it’s better to make a mortise first and size the tenon to fit). Open one leg component for editing and zoom in for a close-up view of the top area, where the stretcher touches. Switch to X-ray mode so you can see the tenon even though it’s buried in the leg. Trace over the base of the tenon with the Line or Rectangle tools. This produces a tenon-sized area on the leg. Use the Push/Pull tool to push that area to the end of the tenon. Orbit around and repeat for the second mortise.
Modeling a mortise
Using X-Ray mode, you can model the mortise in the table leg off of the tenon in the stretcher. For a higher level of detail, consider offsetting the tenon for a desired tolerance. SketchUp can model to a thousandth of an inch.
That completes the table’s structure. Now you’re ready to attach the top. Use the Rectangle tool to draw a rectangle in place right over the top of the legs. With the Offset tool, enlarge the rectangle for the overhang you want. Erase the original rectangle, give the top its thickness, and make it a component.
Table tops
Just like you’d build it, the table top is the last step in the sequence.
Working in SketchUp as you do in the shop is my final rule for success*. Above all, always work with components (that’s Rule #1). Draw a piece once and make as many copies as you need (Rule #2, which ensures accuracy and makes the SketchUp work go quickly). And keep the measuring and moving to a minimum (Rule #3, which also ensures accuracy).
*Ed note: You can read more of David’s "rules for success" in his book “SketchUp Success for Woodworkers: Four Simple Rules to Create 3D Drawings Quickly and Accurately.”
About the Author
David Heim
David Heim is a veteran book and magazine editor specializing in woodworking. After a 28-year career at Consumer Reports, he moved to Fine Woodworking magazine. David has been writing about and teaching SketchUp for over four years, and never begins any project until he has previewed it in SketchUp first.
More Content by David Heim
Previous Article
Behind the curtain: a conversation with concept artist Chris Rosewarne
Award-winning concept artist Chris Rosewarne discusses concept art as a practice and profession. Review his...
Next Video
Our friend, Joshua Cohen
Joshua Cohen is a longtime SketchUp user and the owner of Fat Pencil Studio (fatpencilstudio.com). Based in...
