SketchUp Layers: Part One – The Sacred Layer0
October 10, 2016 Daniel Tal
Daniel Tal and Bonnie Roskes have teamed up to create 3Daily.net – a blog on SketchUp and all things related to 3D. Daniel is a landscape architect and masterful SketchUp trainer and author. Bonnie runs 3DVinci, which features a wide variety of SketchUp books and projects for all ages. The following is adapted from Part One of their three-part series on the use of layers in SketchUp.
Layers – they seem simple enough. Place a SketchUp entity on a layer, turn off the layer, hide it. Each entity sits on only one layer. What could go wrong?
Actually, quite a bit. When you model using groups and components (which all good modelers do), and start placing groups, components, or loose geometry onto different layers, things can get a little messy.
In this post, I’ll discuss the fundamentals of layer placement. In Part Two, you’ll see some case studies of highly detailed models that follow the same principles. Part Three will cover scenes, which give you control over which layers are displayed.
Layer0 Fundamentals
Here are the best practice rules for layers:
  • Create all loose geometry (faces and edges) on Layer0, never anywhere else.
  • Only move groups and components to different layers.
To illustrate the hows and whys, I’ll use this simple model of a kitchen set:
Loose Geometry
Hierarchy of groups and components in the Outliner.
A perfect model consists entirely of groups and components – no loose geometry. But for purposes of demonstration, this kitchen set model consists almostentirely of groups and components. There is some loose geometry – some faces and edges that are not included in any groups or components.
The Outliner shows all groups and components in the model. I’ll focus on the table – the table components right now are just the four table legs. There’s no group or component for the table top or for the table as a whole.
The loose geometry consists of the faces and edges of the tabletop. If you can click a face to highlight just that face, you know it’s not part of a group or component. This is a modeling no-no.
With just one layer in the model to start, “Layer0,” all entities currently sit on that layer. But I’m adding three new layers – one for just the table legs, one for just the table top, and one for the entire table.
Layers panel showing Layer0 as the active layer.
(Incidentally, the filled radio button to the left of “Layer0” means it’s the active layer. Which means anything you create sits on Layer0. While you canmake another layer active, DON’T DO IT. It’s very easy to accidentally leave a layer active, create more on it than you intended, and later try helplessly to figure out why your layers aren’t making sense.) Anyway. . .
Moving Entities onto Layers
As stated above, the best practice is to keep all loose geometry on “Layer0,” because it’s easy to make errors when loose geometry goes on other layers. (Remember, only groups and components should be moved to layers.)To show this, I’m selecting a few loose faces of the table top. No edges are selected, and a lot of faces that should be selected as part of the table top are not selected. (A common rookie error.) These selected, loose faces are (wrongly) placed on the “Table Top” layer, which is done via the Entity Info window:
The four table leg components are now selected and (rightly) placed on the “Table Legs” layer (because it’s OK to move components):
Now the entire table – legs and loose-geometry table top – are made into a group and placed on the “Table” layer:
Why Loose Geometry on Layers is Problematic
Now comes the test. If I hide the “Table” layer, the entire table disappears from view. Good so far.
If I hide the “Table Legs” layer, the legs are gone. So even though an object (table legs, in this case) is supposedto reside on only one layer, a group or component can actually reside on more than one layer if it’s nested inside a larger group / component. In this example, the table legs are on both the “Table” and “Table Legs” layers.
Finally, here’s what happens when hiding the “Table Top” layer. Some of the faces disappear, but the rest of the faces and edges are still showing. It's a mess.
Clearly, this is an extreme example – you’d probably have the presence of mind to keep all loose table top entities in the same place. But it’s quite easy to select only faces and not edges, or vice-versa. So stick with the “Layer0 for loose geometry” rule to prevent any problems like this. When models become complex, it gets much easier to place things where they have no business being.
The Right Way
Here’s how this model should be handled. All loose geometry of the table top stays on Layer0 . . .
. . . and after you make a group of the entire table top, the group is moved to its layer.
Next in Part 2, Daniel presents some case studies of layer use in highly detailed models.
About the Author
Daniel Tal
Daniel Tal, ASLA, is a professional speaker and a registered landscape architect with over 17 years of experience. He is a 3D modeling and visualization expert, has authored two books with Wiley and Sons: SketchUp for Site Design and Rendering in SketchUp, and is the tech-editor at large for Landscape Architecture Magazine. Tal runs a 3D modeling and visualization studio for Stanley Consultants, a 1,000 person multi-disciplinary engineering firm.
More Content by Daniel Tal
Previous Article
Introducing the Advanced Camera Tools
Advanced Camera Tools is the new and improved Film & Stage Plugin. With new features and accessibility, you...
Next Article
7 reasons to get yourself to 3D Basecamp 2018
Don't know why you should attend 3D Basecamp? We have 7 reasons that will make you want to come.
Sign up to get tips & articles sent directly to your inbox!
First Name
Last Name
Industry
Country
State
Province
Company Name
Company Size
I understand that by submitting my personal data on this form it is subject to the SketchUp Privacy Notice. I agree that Trimble Inc. (owner of the SketchUp product line), its authorized representatives, and its group of companies can process my personal data.
Thank you!
Error - something went wrong!
