The Boundary: The Petersen House from SketchUp in animation
The Boundary animates their design of the Petersen House, which is used on the SketchUp site.
From commercial to residential builds, Scott Miller from Remington Development Corporation uses the SketchUp suite of tools to perfect the conceptual design process.
SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
