Scenes are a way to record various SketchUp settings. Using these recorded settings, you can create fly-throughs, shadow studies, different modeling environments and more.
Previous Video
SketchUp Training Series: Section Tool
Learn to add, move, reverse and toggle section cuts.
Next Video
SketchUp Training Series: Match Photo part 1
Match photo is a powerful tool to create models using photographic reference. Learn the basics of how to se...
Pushing The Boundary with architectural visualization
Virtual Collaboration – Shannon Lightfoot | 3D Basecamp 2018
McCarthy Building Companies, Inc.
VDC Manager
Virtual 3D mock-ups are created to represent the actual physical mock-up to be constructed later in the project. They are used as a means to coordinate c
Virtual Design and Construction at Mortenson Construction
For years Mortenson Construction has been an industry leader in using technology to improve customer experiences and build world class facilities. We paid them a visit to check out some of the gorgeou
[Skill Builder] How to get the best performance with a large model
Using inspiration from Matthew Nicholl's 2018 3D Basecamp presentation, we give you a few tips on how to optimize your large SketchUp model to prevent it from being too slow while you are working on i
Dream it, design it, and experience it with Maciej Fijalkowski of VR Sketch
[Quick Win] Use Section Planes to view inside a completed model
Designing an Architecture Career: The Nuts & Bolts
For architects, getting your degree simply is the beginning of a difficult journey of achieving a career as an Architect. Here's Adam Osterhoff's experience.
[Quick Win] Resizing your circle with cardinal points
Did you know that when you draw a circle the corners that meet the axis are called cardinal points? If you click on those cardinal points, you can quickly and easily resize your circle. Follow along a
[Quick Win] Using Outliner to navigate into nested groups
Trying to edit your geometry? Simplify your process by selecting your outer group, choosing Outliner, and then navigating into your nested group. Follow along as we show you how to do this in SketchUp
Trying to use shadows in your SketchUp model? Follow along in this quick win as we show you how to create a shadow study template using shadows and scenes in SketchUp.
Ryan Companies uses SketchUp Pro for virtual design and construction
Ryan Companies is an all-in-one shop that includes development, real estate management, architecture, engineering, and construction. See how the team coordinates with different departments.
Check out Skimp, the new extension from mind.sight.studios. Skimp simplifies meshes and speeds up the importing of complex files into SketchUp!
Get a copy of Skimp at: https://skimp4sketchup.com/
StudioJDK: Utilizing SketchUp, Photoshop, V-Ray, and Vue to create stunning illustrations
It’s much more common for designers to use SketchUp as part of their working process. We sit down with StudioJDK to get a better sense of exactly how these incredible compositions come together.
We've enhanced SketchUp & LayOut: See what's new in 2019.2!
We're excited to announce we've enhanced SketchUp & LayOut for 2019. We've worked hard to update our top features, so see what's new for our 2019 update.
[Quick Win] Modifying geometry with the erase tool
Did you know you can use the Erase tool to select geometry for modification? This quick win comes in from SketchUp forum user, @MikeWayzovski. Follow along as Aaron clicks, drags, and selects the area
