[Skill Builder] Window Components
Part 5 of the Architectural playlist. This time; deciding what kind of window components to use in your model.
The SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
Trying to use shadows in your SketchUp model? Follow along in this quick win as we show you how to create a shadow study template using shadows and scenes in SketchUp.
