Stand-ins aren't just for movie stars! Learn how to use the Components window to swap low-poly proxy components for highly detailed models with just a few clicks!
Download the model here
From commercial to residential builds, Scott Miller from Remington Development Corporation uses the SketchUp suite of tools to perfect the conceptual design process.
SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
