Is there a way to round off corners in SketchUp? Yes! Yes, there is! Check out Fredo6's Round Corner extension! Download Round Corner right here.
And don't forget to install LibFredo, too.
The SketchUp 2021 brings new tools and features to your workflow so you can design delightfully on an informed foundation.
Trying to use shadows in your SketchUp model? Follow along in this quick win as we show you how to create a shadow study template using shadows and scenes in SketchUp.
