The right way to use Follow Me
October 21, 2011 Aidan Chopra
When it comes to using the Follow Me tool, most folks have it wrong. There are actually two different ways to use Follow Me, and for complex extrusions, one works way better than the other.
Follow Me: The Hard Way
In most cases, the wrong way to use Follow Me is to activate the tool, click the face you want to extrude, and attempt to drag it along a set of edges. For complicated extrusion paths, this can be painfully inefficient.
Follow Me: The Right Way
Next time you need to extrude a face along a path, use Follow Me this way:
  1. Make sure your extrusion profile (a face) and your extrusion path (one or more edges) are set up the way you want them to be.
  2. Select (with the Select Tool) the edges that make up the extrusion path you want to use.
  3. Activate the Follow Me Tool by clicking its icon or choosing Tools > Follow Me. When you active Follow Me, the edges you selected in Step 2 will appear to deselect; they won't be highlighted anymore. Don't worry, though -- they're still selected.
  4. Click (with the Follow Me Tool) the face you want to extrude.
  5. Everything happens in a flash. Voilà!
That’s all there is to it. You can take your time selecting exactly the edges you want. You can orbit, zoom and pan in order to select a complex three-dimensional path. No more cussing and sweating while you try to get the extrusion to go exactly where you want it to. Sometimes a little knowledge can save a lot of headaches.
About the Author
Aidan Chopra
Aidan was a beloved member of the SketchUp team for 10 years. He birthed this blog, taught countless SketchUp classes, authored the SketchUp For Dummies book, and is a jolly fellow indeed. If you'd like to learn a little more about Aidan and his new endeavor, check out Bitsbox.
More Content by Aidan Chopra
Previous Article
2030 Commitment Report Spotlight: Kyleen Rockwell of HKS Architects
This commitment report spotlight is on Kyleen Rockwell of HKS Architects. See how she's incorporating build...
Next Article
Can you do that in SketchUp?
In expos and conferences, in studios and on job sites, in workshops and meetups, in makerspaces and classro...
